Just wondered if people use and form of sealant (eg plumbers gold) on certain plumbing joints? Specifically I was curious about the ones below:
Tap connectors (on the fibre washer)
On a pop up basin waste
Around flush valves (where the threaded part is connected to the cistern)
On the flush valve seal between the cistern and the pan on CC toilet
On the coupling bolts on CC toilet
On 40mm compression waste fittings
