Hi Guy's .. a bit of advice if you could please... Ive fitted a new kitchen and bought Wicks Tile effect laminate flooring to put down. the floor is the modern MDF floor board things (not nice)... but in good shape and humidity okay etc...
however, reading the instructions, it says leave a 12.5mm gap around everything!.. the kitchen is 5mtrs x 3 mtrs and has the units where the sides jut forward beyond the kick boards at the ends.. if I'm going to leave 12.5mm around this lot it will look a right dog.
so Question is... do I need 12.5mm or will less do?.. and if so, how small can I go?
and second question is, how can I fill / cover the gap?... would be good to put some very soft silicon in there maybe.. I don't like the quadrant stuff around all the units. even flat stuff is a bit naff.. .. any suggestions?...
cheers....
cheers....
