loft extension - necessary to remove old insulation?
14 Jan 2010
London
hello
my builders are doing a loft extension and have started putting in the new joists between the steels, looks the dogs donuts . is it necessary to remove all the old insulation as it looks fairly dirty and now its got some nice sawdust and bit of other debris on top or am i just being an anorak and it doesn't matter?
thanks jo
Hey Jo.
The primary factor that may reduce the useful lifespan of fiberglass insulation is settling or compaction. To maintain maximum insulating properties, fiberglass should remain in a fluffed state as when originally installed.
Having said that, it might better to get it done now, and not having to rip the floor up later on?
Hey Jo.
thanks for that,
well, its been there for donkeys and i'm sure its pretty knackered, obviously they will be putting all that kingspan stuff down on top of the old existing joist , i suppose i was wondering is it not better to remove it, as i think its use will be fairly limited in terms of insulation, and its now contaminated with sawdust ect, fire hazzard? or would removing it just be unnecessary work and its doing no harm there so just leave it
cheers jo
"If it's not broken, then don't fix it" I say...
No harm in a quick vac of all the saw dust? :)
It shouldn't do any harm to leave it in position.
But remember that to aid fire resistance of the new floor, you need to put 100mm of quilt between the new floor joists, supported off chicken wire stapled to the sides of the joists.
Cheers for that and yes i had a look this morning before going to work and the chicken wire has started going in
best
jo
