That's what they are designed for.That makes me wonder if the 12 controller that switches to 240V would be safe to be left on continuously.
Fans of that type are usually also wired to the lighting, so that when the light is on, the fan runs regardless of humidity, and continues to run when the light is off for a few minutes due to the adjustable timer.
At any time if the humidity level is too high, the fan will operate regardless of the timer or lights.
Humidity sensors are often more trouble than they are worth, as humidity varies due to the weather and time of year.
It's also unlikely that an expensive SELV fan is required anyway, and given that the controller is usually fitted into the loft, an inline extractor would be a much better option.
Thanks flameport, I would have gone with the inline fan option, but there is an existing 240V fan in place in the wall and it's much easier just to replace that. Considering the location of the fan an IPX7 (SELV) fan rather than an IPX4 (currently) seems worth the extra cash. I think I've made up my mind that I'll have a simple solution without humidistat, just on/off at the wall switch
