A central heating circuit has a lot of individual items that can trip an RCD
Any advice on fault finding. i.e isolating individual parts to test insulation resistance.
Insulation resistance continuity testing of motors is something I have little experience of.
Knowing if a valve or pump is faulty is difficult as I not really sure what results I should get, and how you can test them with out having to take the thing apart.such as a valve.
Also disconnecting items
For example if I disconnected the pump to see if that stopped the tripping.
But would that remove a link in the chain of operation and stop the system working as it should so not give useful results. ( and the issue of the boiler being powered with no pump to circulate water concerns me)
Thanks .
Thanks .
