The problem that is, skeilings
18 Oct 2013
London
My house has plenty of skeilings and as part of our remodelling of the entire house, we are able to remove a few of them in rooms new rooms will be created with new walls going up into the loft or 2nd floor extension which will enable us to remove them.
However, generally speaking, am I right in thinking that unless you:
a) change the pitch of the roof above, or
b) have a square a new square wall abutting the skeiling;
it is not possible to remove the skeiling and have high square walls in the room? See my pics below.
This one my wife really wants to have removed from our bedroom as we have a low height ceiling as it is.
I guess in this photo below, we can remove the skeilings because the wall enables us to do so. The joists for the loft extension from the 1980s that you see will need to be replaced anyway because the previous owner badly notched into them such that an RSJ is two thirds into the joists.
Loads of skeilings in Sussex and a coomb is a valley;)
Can someone please revert back to the original questions - looking at the pics I attached above, what are my options if I want to remove these things if I want square ceilings, is it even possible?
looks like you can remove them on the interior wall sides which are there for symmetry, but not the exterior because as you say, you would need to alter the roof pitch.
