- Joined
- 27 Jan 2008
- Messages
- 29,214
- Reaction score
- 3,582
- Location
- Country
1. Combine the separate lighting and power meters into one.
2. Use earths with supplies (requirement under regulations)
3. Use earths on lights 1966 I think?
4. Use of ELCB (requirement under regulations for TT supply)
5. Drop the use of ELCB-v
6. Change from L = live to L = line. (If it ever meant live?)
7. Require RCD on out door supplies.
8. Require RCD on near all supplies 2008.
9. Distance socket to sink (if ever)
10. Distance isolator to cooker (if ever)
11. Change from 240 to 230 volt.
12. Change flex colours
13. Change fixed wiring colours
14. Change from 7/0.012 to 2.5mm²
15. Change from all copper pins 13A plug to insulated top section.
16. Change in earth bond to all metal
17. Change back so metal window frames don’t require an earth.
18. Change removing some earth bonding in bathrooms 2008
