I have a WB Greenstar W30si MK IV installed 2013, and the control panel has a mechanical timer, and on-off switch. Unfortunately it is in the kitchen at the far side of the flat, and I would like a thermostat/timer/switch nearer the living room.
Can anyone recommend a compatible and reliable unit that will do the trick? And would be easy for a DIY fit?
Also, is wired (I can easily run hidden wires through the loft etc to the desired location - maybe 15m or so needed, with the distance maybe 7 metres as the crow flies) more reliable than wireless? One issue putting me off a wireless version is that due to walls etc, trying to use the modem over a similar distance gets frequent disconnections.
