Hi all,
My boiler has been playing up for a while now.
It is stuck in a loop where it fires up for a minute (or less most the time) then cuts out, then it makes a horrible noise then tries to fire up again and fails. After couple of attempts if fires up but then it cuts out again not long after. It carries on doing this throughout the period its set to be ON whether I manually turn it to be on constant or when its on a timer.
I have uploaded a video for you guys to see. The video is 3 minutes long, I was going to shorted it but thought it might be a bit better in real time.
When the video starts its fired up
@10 seconds it cuts out
@1 minute 5 seconds it tries to fire up again (fails)
@2 minutes 55 seconds it fires up again (successfully)
@3 minutes 18 seconds it cuts out again
This is the sort of loop I get throughout the time it is on.
Hope someone can help.
Chris
Chris
