I want to change my 4 ft kitchen window as it's old and the double glazing has blown. Its a wooden frame with aluminum and a 10 mill gap in the glass. The house was built in 1971. The brickwork above the window looks like it might sit on the frame but I am not sure. The brick course is laid the same way as the rest of the brickwork. One window was already changed before I moved in in 2007 to a uvpc unit and you can see the base of the bricks above the top of the window. There was no mention of any problem in the survey with that window and lintels present or not present.
The wood above the windows is just a decorative pergola. The first 2 pics are from the window I want to replace. The last 3 are from an 8 ft window that was already there before I moved in.
Thanks for helping.
Thanks for helping.
