t&e cable for 2 way switch.
20 Nov 2008
Wiltshire
Is it acceptable to run a single conductor next to twin and earth to allow me to rig up a 2way switch? rather than buying a reel of 3core and earth.
Provide it has insulation ( red or brown ) and an outer sheath ( grey ) then yes, but buying single core might be un-economical compared to a short length of 3 core and E
thanks for your reply Bernard. I have plenty of t&e, so for the short length I need I will just use that and utilize the brown wire only.
Connect the CPC(earth wire).
Also, you could attach the Blue to the same terminal as the Brown.
You should sleeve the Blue with Brown but it will be obvious and all conductors will be Line so...
It could be sky blue pink, just as long as the insulation isn't green / yellow ( or green ) and the sheath is not the same colour as the insulation. ( so it can be clearly seen as insulation and sheath being separate material ).
... just as long as the insulation ... and the sheath is not the same colour as the insulation. ( so it can be clearly seen as insulation and sheath being separate material ).
Is that now an actual rule?
Going back a while, we used to use Red/Red singles and Black/Black singles regularly.
Does the current edition of BS7671 actually say that plain green may not be used as well as green/yellow?
I don't know but common sense suggests that plain green could imply earth so best avoided for live conductors
Is it a rule that sheath and insulation must be different colours ? Maybe not but as they have to be leaid separately when the cable is manufactured having sifferent colours would be a lot easier.
Wasn't there a big discussion a while back about HVAC eng's using g/y for a switchwire?
I'm sure there was a consensus that it was, while not desirable, compliant (at that time anyhow).
