Hi there
Recently moved into a new property and I am looking to turn the garage into a "proper" garage - with a car and everything!
At the moment there is a light and a double socket. Run off the "ground floor sockets" circuit and isolated by a 13A fuse which is in a blanking plate in the kitchen.
In order to have the following:
2 X additional double sockets
2 X additional lights (plus an extra switch)
1 X socket to power a hot tub (plug in garage but hot tub outside)
Would it be best to:
Find the main input and add a small consumer unit with a ring for the lights, one for the sockets and one for the hot tub plug. Changing the 13A fuse in the kitchen for a big red switch with a 13A fuse inside it?
Assuming that is all correct do I need to get it signed off? It is in an attached garage. I would have the assistance of an electrician who isn't fully qualified to sign off work. I am confident in my own ability, changing sockets and light switches and I understand how electrical circuits work. Part P regs confuse me a little, modifying an exisiting circuit in a garage is non notifiable as I can read, but as I'm adding a fuse board?
Advice would be appreciated.
