I'm just about to start putting in my first kitchen. The old one was previously removed by other people and one of the waste pipes was cut off at the wall (inside). Not a problem just replace it. The size appears to be different from what I can get at local DIY. Original appears to be 46mm everything now seems to be 40mm.
Has the size changed?
is the larger size (46mm?) still available?
Is there any reason to stick with the larger size if still used?
Cheers
Simon
Cheers
Simon
