And am I seeing things, or does that look like single concentric with the outer strands split off to the neutral & earth connections, so that there's no N-E separation on the feeder?
Ah, looking more closely I see that now. At first I thought that was blue tape.If it was straight con the outer woudn't be insulated.
There should be a cover over the split-con. DNO's use them on the incoming cables. Not sure if they are available separately or as part of a kit.
Those swfuses come with a cover, perhaps the 'installer' couldn't be bothered to fit it!
Looks like access for the PME earth terminal.
