Over the last 3/4ish months we have hit a problem a coupe of times I can't quite work out.
We have a Worcester Grecnstar 24RI boiler, Drayton Tempus 7 programmer and a Nest. We have noticed that the central heating has not turned off when it should have.
Nest was showing as off.
I turned the heating off on the programmer (essentially removing the Nest from the equation) and the heating still stayed on.
If I power cycled the boiler OR removed/refitted the tempus from the wall bracket then the boiler would turn off and then stay off.
As mentioned it only happened a couple times but I am not sure where to go next to diagnose the problem (which is obviously made tricky by the fact its a intermittent problem.
Any recommendations?
