- Joined
- 13 Jan 2016
- Messages
- 3
- Reaction score
- 0
- Country
Can anyone recommend a good prv as I don't know anything about them?
I want to fit a new shower in the bathroom as part of a re-model. I want to change from our existing electric shower to a thermostatic mixer one run off the boiler. I know our combi boiler (Worcester Bosch Greenstar 28Cdi) is more than capable of handling this, and we don't have any appliances that run off the hot water from the boiler (i.e. the washer & dishwasher are cold feed only).
However, I was concerned that we have quite high water pressure. I bought a gauge and measured it last night and found it was 6Bar/90PSI. The specs for the shower valve that I want to install (which I haven't bought yet) state a max pressure of 5Bar so I will need a PRV. I also checked the pressure for the hot feed as well and it is also 6Bar (not really a surprise as it's running from the combi boiler).
So I will either need 2x PRVs for the shower or I thought that I could just put 1 valve in right after the main stopcock for the house, thereby reducing the pressure for the whole house in one go - this would also be beneficial in other areas as we have some quite noisy taps when running due to the high pressure as well.
So the question is, does that sound sensible, and also looking for recommendations on a make/model of PRV and what sort of maintenance is required on them.
Thanks in advance,
Dave
Thanks in advance,
Dave
