- Joined
- 27 Sep 2004
- Messages
- 1,300
- Reaction score
- 83
- Country
Got a bit of an odd one here. Have a customer with a water pump which is plugged into a socket with a 13A plug. It is controlled by a float switch and pressure switch which operate a contactor which brings on the pump.
Pump is 2.2kW 10A FLC
He phoned to say it was blowing fuses every so often (perhaps one every 2 days)
He has changed the plug with a new one. All OK inside that.
I get there check the motor - all OK there nothing down to earth and windings seemingly ok. The only thing was the line and neutral in the terminal box had got hot and blackened so re-terminated these.
I also fitted a 10A motor overload as there wasn't one previously.
Replaced fuse 13A and all OK, drawing between 8-9A.
Customer phoned this morning to say the pump had stopped again, but the fuse had blown, and the overload stayed ON.
Why would this happen? Surely a motor overload set to 10A is going to operate before a 13A fuse (unless a dead short appeared perhaps) but I can't see that has happened. He replaced the fuse again and its all running again.
Ideas what to look at? Thanks.
