IR testing a USB socket.
When installing them, what about using a deeper box, and wago connectors so the socket is on a very short spur that you can disconnect with ease while keeping the ring connected?
(I am a HMO landlord, and the USB sockets are now being used a lot in HMO bedrooms!)
I personally don't think it is a brilliant idea to add unnecessary connections in a circuit just to make (occasional) testing slightly quicker.
If the manufacturers would only make all these USB sockets shutter-switched, then the problem would go away.
On a EICR I would state L-N as a limitation and just to L+N to E.
On a MWC I would do the same... you never know what else could be connected anyway
On an EIC I wouldn't have to worry as a new circuit I installed wouldn't have USB chargers fitted:P
The DP Switch fused connector unit also saves power wastage whenever the USB sockets are not in use.
Wouldn't that introduce another connection though?
I personally don't think it is a brilliant idea to add unnecessary connections in a circuit just to make (occasional) testing slightly quicker. ... If the manufacturers would only make all these USB sockets shutter-switched, then the problem would go away.
It would, but they would be permanent factory-produced connections and, more to the point, would not have to be undone/re-done for testing.
So would shutter-switched USB power outlets. Also, has it no occurred to you that some people might want to draw more than 13A total from a double socket - the 13A fuse in an FCU would probably allow 20A to flow for quite a long time, but it's hardly good practice, and the fuse would probably get very hot.
I wonder if these USB socket-outlets have passed the temperature rise test in BS 1363?
Probably not necessarily! As an example, the MK K2743 claims compliance with BS 5733, IEC 61558-2-16, IEC 61000-6-1 and IEC 61000-6-3, but no mention of BS1363.
... which, of course, might be taken to some to indicate that they may not be connected to a standard ring final circuit, unless one reduces the OPD to 20A :-)
