There is another option you might like to consider, and that's a key switch which cannot be operated accidentally. You would need to make up a combination key switch and fuse unit out of a grid range by combining parts such as the following:The reason for me asking is, the 45A has a switch that requires a good amount of force to switch on/off whereas the 13A can be switched on/off by the press of a finger. The location of the switch will be behind a cupboard, quite low, and i am afraid if someone is trying to access the (feeding) double socket next to it, might switch it off without realising it. Needless to say the adults in the house are going to be aware of it but you never know.....!
Brilliant advice and I understand exactly what you mean PBC, that complies 100% with my needs, thank you!There is another option you might like to consider, and that's a key switch which cannot be operated accidentally.
Hot in the height of summer, but the evenings then are just glorious. And after a rainy spell a week or two ago, it's sunny again and the forecast is for a high of 74 degrees this afternoon - Not bad for the middle of February!P. S. Nice place you moved to, Redding, nice weather all year round!
Terminate the SWA on the outside surface of the wall using a waterproof boxHow do I terminate the SWA, which comes through the outside wall into the living room, into a 47mm dry wall box (see image).
Thank you freddo, option is registered and saved in my hard drive for further investigationUse a metal dual box rather than 2 single boxes and fit 2 plasterboard lugs. Fitting an armoured cable will still be fiddly if you aren't used to it.
PBC, you've made it againIf that might involve too much cutting and patching of the wall, another option would be to mount a weatherproof junction box on the outside wall and run the SWA from that.
These are made for the purpose
Do not forget to order the earth clamping bar to make earthing the armour an easier job
You then wire from the external box through the wall using regular 2.5mm² T&E cable (I'm assuming you are using 2.5mm² SWA?)
If the T&E comes out of the back of the box and goes straight through the wall, none of it will be 'exposed' - either to 'the elements' or to potential trauma.... my only "objection" would be: the little piece of T&E coming out of the wall and into the weatherproof junction box....., is it not a regulatory(?), but most importantly, a safety issue??? ...
For a start, many people use only 2-core SWA (for L & N), the armour being the only earth connection. However, the main point is that the armour has to be earthed for safety reasons - it is not there only to provide mechanical protection. By having it earthed, this more-or-less guarantees that if anything (e.g. a spade or other tool) pentrates the cable and comes into contact with the L conductor within, then this will cause some protective device (fuse, MCB, RCD etc.) to operate, thereby cutting off the power.I have to ask: why does the actual SWA, the steel protection, need to be earthed? Not that I disagree! Its just a curiosity question, considering that I use conductor 1=L, 2=N and 3=Earth.
The external ones are longer because they have an additional 'stage' to them. Internal ones have just one nut which grips onto the armour. External ones have an extra ('outer') 'stage' which seals around the outer covering of the cable, to 'prevent' water ingress......I suppose i go for "external" glands, and again the question: where is the difference apart from the term external and internal? One is shorter than the other but ultimately they look the same, doing the same "job"
He probably could. I hesitated to mention it because, although I would very happily do that (and advise people to do it) if the cores were going straight 'from box to box', or through conduit, the inner 'sheathing' (or whatever one calls it) does not seem very tough, and I might worry (if advising others!) a little about it being pushed through a 'jagged hole' in masonry. Having said that, if I were doing it for myself, rather than 'advising others', I'd probably just do itI haven't read all the rest of the post so it may not be possible. .... Can you not run the swa cores through the wall?
Taylor, I can see that the glands are supplied with "earth tags" the brass washers with the extra little hole, I assume for the earthing screw; so I understand your advise is correct. And the reason is???
I'd run through conduit, but wouldn't consider doing it through "bare" wall. I don't think that inner layer of SWA is really designed or intended to be used as a protective sheath, as such.I hesitated to mention it because, although I would very happily do that (and advise people to do it) if the cores were going straight 'from box to box', or through conduit, the inner 'sheathing' (or whatever one calls it) does not seem very tough, and I might worry (if advising others!) a little about it being pushed through a 'jagged hole' in masonry.
Exactly my point. If you're talking about leaving the cores within that 'sheathing' then, as I said, one would also have to run a separate earth conductor (at least at the house end) in order to earth the armour of the SWA.I'd run through conduit, but wouldn't consider doing it through "bare" wall. I don't think that inner layer of SWA is really designed or intended to be used as a protective sheath, as such.
