Reference to
Certification Scheme For Individual Unvented Hotwater Operatives
Probably because they have a vacuum release valve / bursting disc for when a vacuum is created by
1 water being drawn off faster than the mains can re-supply the cylinder.
2 after a heat up period when the water has expanded, both the heat source and water supply are shut off, the water would start to cool, contracting in volume until a partial vacuum was created.
A vacuum can only develop in a vented tank if both feed and expansion pipes are blocked, either by a plug left in after work on the system or by freezing and water is drawn off.
Only just 30 years, they were not permitted until 1986 if the NiC are correct
The whole document is of value when deciding on vented or unvented.
I've seen serveral imploded vented cylinders over the years. It's amazing what some people will do when there's limited tank(sorry cistern) head!! Never ever seen an imploded UVC.
Unvented cylinders have been around a good 30 years too
NiC training said:Traditional in this country, hot water supply has been based on a cold water feed from a storage cistern to hot water apparatus that is vented to atmosphere.
Prior to 1986 it was not permitted for hot water storage apparatus to be connected directly to cold water service pipes subjected to mains pressure.
The only exceptions to this bye-law were: -
Instantaneous water heaters and storage type water heaters with a capacity of less than 15 litres.
The reason for this was that there was a possibility of contamination of the water in the water main caused by back-syphonage of hot water into the cold water main or wastage due to expansion as in continental systems.
In 1974 the BACK-SYPHONAGE REPORT was published. It looked at the dangers of back syphonage, its causes and how it could be prevented. The one important conclusion of that report was that provided a satisfactory level of control is applied, mains connected unvented hot water systems could be permitted in the United Kingdom.
