I am preparing a shower enclosure for retiling and I need a bit of advice on how to proceed. Some photo's attached for clarity.
One side was tile on plasterboard. I plan to replace that with suitable water resistant board. The other two sides are on plastered brick. I have several problems to figure out.
1. The surface - the thin skim of plaster has partly come off leaving very hard grey bonding underneath. Do I need to get all the brown plaster off? Can I tile directly on to the bonding, or do I need to prepare it in some way? The tiles are 600x300mm and quite heavy.
2. The walls are not square - there is a gap of about 25mm at the front on one side. What's the best way to build that up? I considered a strip of backer board, or adding more bonding to the wall using a batten to define the right thickness.
3. The tray, which I hope to keep, has a small bit of the upriser chipped off at the back. Is it safe to ignore that, or is the tray a write off, or can I repair with something? I know some trays don't have uprisers so I hope it's not a problem
4. Do I need to tank all this? I have been given a spare tub of tanking compound and tape from a friends' job.
Many thanks to anyone who can help me with this.
John
John
