Has anybody changed their gas/elec meters to smart meters? Is it a smart move?
It might be for your mum if she had a priority status which kept her with power when she might otherwise have had it cut off.The electric company may have the ability to turn off the power remotely but that hardly is an advantage for the user.
The reasons for rolling out SmartMeters are pretty much the same though.All of which has absolutely nothing to do with what is happening in the UK!
It's more than just a regular monthly or quarterly reading that a meter reader takes though. They can send data relating to usage on different days and during different times of day, so the power company can record times of heaviest usage at each home etc. In some cases the units are sending not only their own data but also acting as relays for other SmartMeters in the area.As far as I can tell all the "Smart" meter does is send info on what power you are using direct to the electric company so they don't need a meter reader.
Do you mean now, or in a few years time when the shortfall in generating capacity leads to inevitable power cuts, and where smart metering (and smart appliances - both are needed to work together) might save you from some of them?I am still desperately searching for what the benefit is for me,
