I have my combi covered by British Gas. There have been a series of issues recently around intermittent hot water. The PCB has been changed and this seemed to resolve matters but it now seems that the wiring looms are to blame and these are being replaced tomorrow.
However, the hot water now cycles on and off with no apparent flame modulation. This started after the PCB replacement and has continued after a further PCB replacement. The plate heat exchanger has also been replaced. So has the pump.
The hot water gets very hot and then the flame cuts out. On the maximum heat setting, the flame remains on with lots of very hot water delivered. Turning down the temperature setting results in the on / off behaviour on the burner. (The lower the set temperature the sooner the burner cuts out having got the HW less hot.)
Similar behaviour with CH i.e. water gets very hot and then cuts out with no apparent modulation.
I know the engineer tomorrow will say that this is OK because if the HW setting is at max, there is continuous HW but I disagree that this is OK. I do not want to have to have only high flow rate scalding water.
I understand that the requested (by the PCB) modulation can be measured by checking the voltage. So my questions are:
1. Where exactly should the modulating voltage by read? On the PCB? Which pins? Or elsewhere? I want to be able to clearly tell the engineer what he needs to measure where.
2. If the PCB is correctly modulating, then this presumably can be compared with the measured gas pressure? (Which I know is not modulating down because the engineer was measuring it on last visit.)
3. Is the issue likely to be incorrect setup of the gas valve or does it need to be replaced? (I think the values he measured were 12mb when running and possibly 20mb on the input.)
4. Am I barking up the wrong tree entirely?
I would very much tomorrow's visit to be the last for some time so any help in making me an informed customer would be much appreciated.
