Manhole cover sizes
23 May 2004
I have to replace a cast iron cover/surround but can't find the size in any material.
Also tried local reclamation yards to no avail.
It is 670mm x 530mm
Are these available anymore, and if so any links?
A lot come up on eBay - if you keep a saved search running for a few weeks one will come up. Make sure you use the right words though - some people call them "inspection covers", others "manhole covers", others "drain covers"
I put your dimensions into google, scrolled down and instantly came up with two hits.
Since I did not have such luck the links you found might be helpful at this point.
