Ok so i have now traced the cabling to see how the boiler and existing thermostat connect.
There are 2 connections coming from the boiler in the below image. Brown and blue going to the thermostat (honeywell t40)
what im thinking is connect the N and L on the nest heatlink directly to the fused spur to power the heatlink separately. Then connect the brown (1) from the old t40 to the (3) connection (Call for Heat) on the nest heatlink and the blue(3) connection from the t40 to (2) connection(common) on the nest heatlink.
The nest thermostat will connect wirelessly from another room powered by usb.
Does the above sound about right?
