Then ( assuming common sense applied to the design of the un-vented cylinder ) the non electrical and purely mechanical safety devices would ( should ) operate and dump water out of the cylinder. Yes that would ( and has ) create the hazard of hot water discharging somewhere outside the building where is might affect / injure people.But what if the 'incompetent person' wired the extra 2 port as a conventional system and didn't run control for the valve through the overheat thermostat?
The trouble is that he's talking bollix![]()
Some qualified people see the risks of putting un-vented cylinders into houses where there is no garantee the house owner will have the systems safety devices insprected and tested on a regular schedule. Is it bollix to consider the real possibility that the safety devices on an un-vented cylinder may not be tested yearly and then only when something else fails is it discovered that the safety devices are not operating to prevent ( for example ) a ruptured cylinder dumping scalding hot water.
Do qualified installers make a point of explaining this need for regular testing of the safety devices to their customers or do they only mention the ( dubious ) advantages of non vented over vented. ?
