I'd really like to get into home auto, though I am struggling to build a good use case to convince my other half. Can you describe the general use you have for the tech, and the difference it has made to home life?
It's all that gubbins that doesn't interest me for a few reasons, one you have pointed out. All my dedicated switches and remotes are present so I have the choice.Home automation can present problems when you have guests staying overnight. You may have to "train" them how to turn on lights if there are no normal light switches for the loghts they will need to use.
Except you can't do a number of things if you're not home so there is no normal way. Automation is the normal way when away.All good to me, except that life's not exactly compromised by doing these things the normal way (eg PIR outside lights, timer plugs for lamps etc). I think she thinks its a solution looking for a problem, and I am beginning to think so too
I might just do it for the fun of it though
Did you not read the message above? Automation isn't meant to be a solution to problems but an enhancement to normal living nor does it have to involve over complicated equipment.I think she thinks its a solution looking for a problem, and I am beginning to think so too
She thinks sensibly. It is a solution looking for a ( non existant ) problem to solve with overcomplicated equipment.
Like most things, it is so easy to knock when you haven't got it or feel you don't need it.
My concern is that home automation often goes a bit too far... and is not user friend other than to the person who installed it. A friend re-thought his home automation after a visit from his parents who could not cope with the system.
I |"automated" the lighting in my cottage as part of the re-wiring. This was to provide a solution to the problems of wiring a 500 year old Grade II listed thatched cottage.
It has additionals function in that after dusk some exterior lights are switched on in response to a break beam detector. Pressing a door bell after dark also turns on the porch light for that door enabling one to find the key hole.
I agree, as said before, having a 3rd party app involved in either your automation or security is fashionable stupidity.If home automation includes any internet connection or a mobile phone app to control something in the house then it has gone to far ( in my opinion ).
