- Joined
- 5 Sep 2016
- Messages
- 2
- Reaction score
- 0
- Country
Hi
I'm thinking of having the the 20mm plastic pipe between the water meter and my house replaced with a 32mm MDPE pipe by a WRAS-accredited moling plumber because the shower temperature goes wild when someone fills a kettle or flushes a toilet.
The house has a gas combi boiler and a mains pressure electric shower and no tanks inside the house. We may want to install a second shower, this time from the combi.
The pipe work has 2.2 bar static pressure, reducing to 1.5 bar with 1 tap open and 1.0 bar with 2 taps open. The water meter 7m outside in the pavement has "15mm" printed in its specification.
It seems to me that I could spend £600-800 upgrading the pipe to the water meter but still have a flow rate problem because the meter and/or pipe upstream of the meter are too narrow. My guess is upgrading the meter and upstream pipe will not be cheap.
My questions: is the narrow bore of the meter something to worry about and if so what's the best way to get a decent flow rate for 2 simultaneous showers without spending more than £1000, say? I prefer to live with the problem or ask people not to use both showers at the same time rather than overspend.
Mark
Mark
