We've got the pictured rad in our front room - it is going to be removed and replaced with a Quinn Round top on another wall.
As far as I can find online from tables etc it is saying the existing rad is about 3200w but this seems to be a bit on the generous side when I compare this to stated figures for the quinn radiators (Quinn Round Top Radiator 600x1400 Double Convector - Rating: 2720watts / 9283btu DT50)
The existing radiator measurements are 1200 x 700mm - does anyone recognise the convector fins and care to guess a wattage/BTU?View media item 98420
Failing that should I be OK so long as the surface area is about the same and spec is broadly similar i.e. both are 8400cm² double panel, double convector?
