Morning folks!
As part of the renovations in my front room we will be fitting a solid oak mantel/beam above the fireplace (mantel dimensions approx 1600 x 200 x 150mm).
I want the fixing to be hidden - we will be losing the back edge by recessing slightly into the plaster on the wall.
In terms of mounting I'd played around with a few ideas such as creating tenons that could be fitted to the wall to fit into mortices in the back of the beam locked in place by a peg driven up from the underside of the mantel...but I think I've now probably opted to go with a french cleat fitted to the wall and a corresponding recess routed into the back of the beam, I'd lock the cleat with a few screws driven again from the underside.
However it has occurred to me that this may not be the best/fastest/easiest way of doing this so I thought I'd ask what you would do?
