hi all,
Our boiler is Potterton Prima F, with EP3002 programmer.
I replaced the programmer and thermostat with hive (http://www.johnlewis.com/hive-active-heating-hot-water-with-self-installation/p2965185)
After the installation the system is working but the feed pump is always on and also the radiators in the bath are always hot.
Near the hot water cyclinder we have one pump (this is the one I have issue with) and two eletric values.
Bath radiators should turn on only when the water heating is on or when central heating is on, but now they are hot all the time and the pump is on all the time and also I noticed the boiler is fireups intermittently I suspect to heat up the bath raditators.
But the hot water and central heating turns on/off as per the hive schedule and works normally.
Any ideas, what's wrong?
