As said above would be the main thing, plus another point (not summer, actually in winter) would be if the doors are open all the way up and you have standard radiators, the heat may be collecting up there before downstairs gets warm. It's possible the same might happen in summer if the suns heating your hallway.
Interesting CJ
My neighbours one was done 4 years ago (30's mid terrace) so it would be done correctly
It depends. 300mm of celotex is going to do little to negate the effect of the sun beating directly through 6 square metres of window and striking a black wall for 12 hoursand that used to get pretty warm in the summer. Are you saying that the cure would be 300mm of celotex on the flat roof and all sides?
