Alarm System Advice
Guys how do I delete assigned keypa
I was about to buy a pyronix enforcer thinking my DIY skills would suffice but after reading this I'm starting to worry it's a beast.
aha mate at first its difficult but you get the hang of it. Trust me, have a look at the youtube videos and the guys here are helpful!
For what ? ....tennis ...lol
On a serious note I allways pre program enforcer panels , test apart from bell box so as an example
Contact on entry door set ABCD final exit, omit , chime
Pir downstairs , ABCD intruder , omit
Pir landing A CD intruder ,omit
A full set
B night set
This is very basic operation , every job is different with different layout and customer requests
Hi why omit?
Hi guys, the alarm is installed and working :) quick question. The alert light keeps popping up, how do I review this?
Enter your code ....what does it say ?
active faults restore required, this only happens when the alarm is set in the day under area A. When it is in area B it is fine, no alerts in the morning. The faults get clear once I am in engineers mode.
Ok try this ....set A from the control panel keep still and make sure no one else is in ....once it has set after the confirmation bleep ...turn off the panel with your code ....is the alert flashing ?
Nope, no alert showing when setting from the control panel. The issue must be the keypad...
Without knowing the layout of your home , where the devices are and what they are programmed as , I can't comment ,at a guess one of your detectors is picking you up on the way in and setting off the alarm on entry ...
Thanks for the reply, I have set the entry sensor as 09 (Area FX) as this is the sensor for entry when on full set and also the sensor I have to go through to go upstairs and back down to unset once on night mode. Is this right?
That's your problem , should be 07 final exit , 09 is part entry/exit , this is used if you have a pir in the hallway and a door contact on front door ,it becomes an entry zone in BCD only to start your timer
oh ok, I did have as 07, I will change it when I get a chance. Thank you
