you seem to be all over the place
my suggestion as i said above is both a 1/4" and a half inch router
start small router with a 12 or 15 cheap router cutter set[about 1-1.50p a cutter]15-£30
then as you progress by more expensive cutters as you wont use that many off a 15 set [perhaps 4 regularly and 4 occasionally]
when you get used to the router think off larger projects and buying a half inch router
what had you planed to do with the oak and how old is it ??
