- Joined
- 31 Oct 2016
- Messages
- 11
- Reaction score
- 1
- Country
your system is already fully pumped (in a roundabout way) the pump is on the return in this case.
what you have is a KOVM valve.
i've not seen many at all, and the one's i have seen i've removed and replaced with motorised valves. which you would be best to do in this case i think.
you might be able to fit the pump and valves down by the boiler if you can get a pipe from the loft down to that location.
someone should be able to tell you exactly how those KOVM valves work,
thanks gasmanstu..... i take it with the current set up there is no way to have hot water without having the heating on? can i swap this straight out for a motorized valve in its location, and run a cable back to the boiler?
