Is anyone aware of a non-maintained emergency light kit to fit existing lights?
The setup i have is as follows:
I have a group of LED Spot lights, of which i want to convert 1 (at the bottom of the stairs) to be a non maintained emergency light, such that for normal use it would light up along with the rest of the group, and if power is lost, the single light will power from the emergency light kit.
The existing light has Live, Neutral and Switched Live (as well as a separate cable for test switch) but i can only find maintained lights or non maintained but are built into an existing light.
I was going to get the AU-MDEM3A, until i realized its maintained only!
Any ideas? Knightsbridge seem to do something similar but their tech support wont give me any info as I'm not using one of their fittings ( will this work with a standard GU10 LED as it seems to indicate i need a driver?), CEF only seem to have for tube lights, and TLC have a kit listed in their non maintained sub category, but it is actually maintained!
Alternative will be that i take apart a non maintained and make it work, or have no emergency light. Note that this is for my own comfort rather then a requirement for any form of regs so not essential...
