- Joined
- 27 Jan 2008
- Messages
- 29,295
- Reaction score
- 3,599
- Location
- Country
I set up mothers house when just her in the house with one thermostat for the day and one at night, so living room was spot on in the day, other rooms using TRV and lock shield valves to be some where near what was required. And a night the bedroom thermostat kicked in so that room spot on and again other rooms just some where near.
I had problems with mother moving the thermostat out of range, so although the living room one could be portable I screwed it to the wall. When it was mobile I found major fault, it did not hand shake, so if it tried to switch on central heating and for some reason it failed to go into run mode, even if that reason was corrected it would not switch on the central heating unless I set it low then high again. Same in reverse, if it looses signal then will not turn central heating off, even when what every caused it to loose signal was corrected.
The Honeywell Y6630D wireless room thermostat worked A1, however the Horstmann HRFS1 programmable thermostat was causing a problem, as to if this was due to swapping temperatures for different times of day, its location, or interference hard to tell. But since screwing to the wall the Horstmann seemed to be doing as it should do.
Then one week ago it all started again. Hunted for cause, however there is nothing to show signal strength so how does one know if on the edge of range or well in range. So step one change batteries, not something one wants to do as it all needs programming again. Still playing up, swapped frequency, still playing up, so swapped a second time, still seemed to be playing up, moved 12 inches to left and a little lower on wall selected so no kitchen cupboards between sender and receiver and it is all working again.
I tried to reposition cordless phone, and the call centre receiver it did nothing to improve things, also moved mobile phone well away from area. At the moment I am not transmitting so not my amateur gear. The TV with wireless connection to router had not moved, the router had not moved, detached house.
Although all working again, I worry about it failing, both my mother and I are very susceptible to temperature changes, I have a mauled hand and if it gets cold I am in a lot of pain. The Honeywell is much further away than the Horstmann but had no problems with Honeywell. In my own house thermostat is hard wired, I use a Horstmann without any problems except for the odd flat battery.
So am I unlucky in mother house? or are Horstmann RF thermostats low in output or something? Is there any way to measure signal strength? If it had failed to work on and off many times I would just say interference, but it ran for 3 months then failed, has any one else had these problems?
