I don't know much about paint, but one of the most important things, it seems to me, is:
IS IT F***ING WATER BASED OR OIL BASED????
So why don't they making it bloody obvious on the tin? Oooh no, I have to read the small print and look for the bit where it tells you what to clean the brushes in. And if you go on the manufacturer's website it often doesn't tell you at all!* You actually have to pick up and actual tin to find out!! Why do they DO this?? Why isn't it on the front of the tin in big letters??
Also, is 'quick dry' paint always water based? So many questions.
OK, take a deep breath, Gerry. I guess my main question is: can you paint water based onto oil based, or vice versa, willy nilly? If for example you want to use an oil-based gloss, do you also have to start with oil-based primer and oil-based undercoat? Or can you mix and match? Does it matter? And why is this info so bloody secret??
Another question: can anyone recommend a sandable primer for interior woodwork?
*Take this example: is it water based or oil based (yes I know it's American, I just happened to be looking at it)? https://www.sherwin-williams.com/homeowners/products/premium-wall-wood-primer
