With reference to the Axor Starck basin mixer tap (made in Germany), as shown in the schematic diagram below Product Ref: 10102000; if I wanted to remove the two tap tails and replace with shorter 300mm length flex tails, what size would be required for this?
It would be 300mm length x 15mm (for UK pipes) x ?
Should the bore diameter be the same? Is the bore diameter 3/8" from the diagram?
Thanks!
Thanks!
