I have shown my structural plans for a rear extension to two builders and they both asked the exact same question. Which was "why has the engineer used a solid wall with insulation on the outside and not a cavity wall?"
Pic attached
A third builder said this is fine and used in modern construction. Go figure now...
I am no expert in walls and insulation, the only standard wall structure I am familiar with is the cavity sandwich of 100mm block/100mm insulation/100mm wall.
For some reason, be it a lot of glazing or something else, my engineer decided to build the wall as in the drawing attached.
Are there any disadvantages to this external wall e.g how do I fix things on the outside and how sturdy is this formation?
Any thoughts, advice most welcome I approach him with the builder's question.
Pic attached
