Worcester bosch boiler
5 Feb 2007
Liverpool
Boiler has just started flooding water from the back. Pressure down on boiler. Had to isolate the main cold water feed to it to stop water. Looks likes its coming from vessel at back or plate. I think vessel as its further up. If the vessel had ruptured would constant water flood out.
It would if the plate had cracked but im not sure if vessel had ruptured ?
vessel is central heating water but could be quite a lot potentially, if its mains water the usually plastic manifold on lhs spraying a very fine jet of water
Yes vessel is central heating , just curious how pressure has gone but its constant water. He has just bought property. If its still under guarantee with bosch as I think it was a greenstar. Would they still cover it if its in a different name. Obviously same property ?
