- Joined
- 27 Jan 2008
- Messages
- 29,008
- Reaction score
- 3,555
- Location
- Country
There is also the so called lazy starter. As the bearing on the starter ware the armature can get closer and closer to the pole shoes, but under starting conditions with a warm engine they don't touch, however with a cold engine the strain means it draws more current, this in turn means a greater attraction between armature and pole shoe, this is enough to bend the armature slightly causing it to touch the pole shoes, it then needs even more current which bend the armature even more. Net result is there is a point where just a little extra strain makes a huge difference in the current required.
Changing the bearings cures this. But a fully charged battery or new battery will also cure it short term. Once spinning the armature and pole shoes don't touch, it is only when nearly at a stall that the armature bends enough to touch. There is many a motorist been sold a new battery when really it's the starter at fault.
