- Joined
- 27 Jan 2008
- Messages
- 29,397
- Reaction score
- 3,615
- Location
- Country
Glad to see not listed as pointless, I have a number of items which have a built in cut off, so once battery drops to a set voltage they stop working, inverter is set a little low at around 11.5 volt, but split charger for caravan set quite high around 13.2 volt, this would ensure when vehicles are left for a long time the battery does not go completely flat.
The big problem is bonnet and boot lamps, if they stick on once closed you don't know. I am sure they could make a timed switch for both if they really wanted to.
