Ballpark figure for windows
1 Feb 2010
Devon
Hi all
Can anyone give me a ballpark figure I should be looking at for 3 windows . They're quite big so not sure how much extra this adds .
W1
2.3 m X 1.5 m X 2 casement openings
W2
1.8 m X 1.2 x casement openings
W3
1.2 x 1.2 X1 casement opening
Located in Devon
Many thanks in advance
They aren't big :)
Why not get a couple of quotes, that will give you a better idea.
You could use an online supplier to get an idea of window cost then add 30% on for fitting.
Way too many variables to just give you a price. What material for a start, PVCu, aluminum, timber (hardwood or softwood?).
Here is a quote I got recently. Residence 9 Windows. Fitted.
1500mm x 1250mm £ 1254.86
1500mm x 950mm £ 1195.52
500mm x 950mm £ 678.06
plus 20% VAT
less 10% discount
As said what material ...and then if upvc what colour? External cills?Toughened Glass? Obscure Glass? Trickle Vents? Fire Escape?
residence9 ...good windows ...touch pricey though!
plus 20% VAT
less 10% discount
Holy shiite. I'm in for a shock. We're after
2400mm x 1200mm (x6) (3x 2 casement)(3x1 casement)
1000mm x 1000mm (x1) (1 casement)
2 standard upvc doors. I'll make sure I'm sat down for that quote. Fook me.
Are you looking at residence 9 though? As standard pvc wont be that expensive from a local company . Also if it is residence 9 , there are quite a few manufacturers offering flush fit casements
To be truthful I've not looked into it yet but it's on the agenda before the summer starts, probably not if it's a much higher spec. Just want decent quality that'll last us.
£150 per square metre, fitting between 10 and 30%
