- Joined
- 27 Jan 2008
- Messages
- 29,224
- Reaction score
- 3,582
- Location
- Country
At night house is too hot, tried switching off central heating with programmer, but then too cold, also tried wireless programmable thermostat which was also a failure, it kept loosing the RF link.
So what I need it seems is a better quality programmable thermostat and it would seem “Nest” is the answer, since this thermostat has two way coms and it can be set to “follow” with the eTRV already installed.
However it will involve some work to install so I want to install it in the correct place.
What I would think will work, is if installed in same room as the eTRV and set to “follow” and placed away from the radiator, then one a cold day the “Nest” will always be colder than the eTRV so if set at nearly the same temperature the boiler will run all the time, which is what is wanted. However on a warm day the “Nest” will be nearly the same temperature as the eTRV so it can be set so it switches the boiler off on a warm day, but not on a cold day. Since the eTRV will “follow” “Nest” then if we turn temperature up or down with the “Nest” then the eTRV will also go up or down by same amount so the system will still work.
Or will it? The question is really what is meant by “follow”? If by follow it means when Nest goes up or down 2˚C then the eTRV will also go up or down by 2˚C then it will work, however if it means when Nest is set to 19˚C the eTRV is also set to 19˚C then it will not, the Nest will never switch off as there will always be a temperature drop between the eTRV and the Nest.
However I can’t find anything in the instructions which explains what “Follow” means.
