- Joined
- 27 Jan 2008
- Messages
- 28,727
- Reaction score
- 3,508
- Location
- Country
I got a laptop from my dad so old when I got it, the battery was just good enough to allow me to save work, maybe 3 minutes, not enough to close it down, however near always used on mains power so did not worry, however noted power supply was very hot, so tried without battery and it ran cooler, so ordered a new battery.
It arrived and seemed to work, but within days the hard drive went so it sat waiting for son to repair for around 3 months, in the mean time I got an email from Amazon to say battery may be faulty and I would be refunded. Not a clue if genuine email or if really refunded.
When I got Laptop back battery was completely discharged and operating system had been changed from Vista to Windows 7, I simply don't have a Vista CD. It took some days but it did start to charge up to around 78% then although the icon said it was charging over a couple of weeks it got lower and lower ending up at around 7%, in this time I have been hunting for Sony drivers, the VAIO VGN-AW11XU/Q it seems was not used in USA and British site showed model existed but not any drivers.
However in the Computer software on this site some kind sole directed me to the UK Sony site with drivers for my laptop, reading reports it seemed Windows 7 is well known for having problems with charging Sony laptops. However instead of getting it working, the update caused a report to come up saying either battery not inserted correctly or wrong type, and auto shut down the PC into hibernate.
Since I had got the email about battery I decided to order another new one. However note new one rated 4400 mAh where old one rated 5200 mAh both 11.1 volt, it has 6 cells.
So I wonder what is wrong with the 5200 mAh battery, from what I gather there is a printed circuit built into the battery, if the fault is the printed circuit maybe I could make one good battery from the two old batteries? I think first thing is try the 4400 mAh battery when it arrives, may be nothing wrong with 5200 mAh it still could be a software fault.
However also seen the videos of Dell computers exploding, so I am not very happy with idea of my PC bursting into flames. The suspect battery is made in China, however most are now made there. The Sony site has a list of serial numbers of faulty batteries, my battery is not on the list.
Has anyone else had problems with Sony laptops when Vista is replaced with Windows 7, and what do you think the problem is, could it be the software built into the battery, would it be worth swapping new cells into old case?
It seems not limited to Sony, the HP laptops have same problem. If it was not such a regular problem which it seems is software linked I would just bin the battery, but so many seem to have same problem.
