I was going to just get a 13amp plug version of the hob and plug it in to be safe, but then I've been told that apparently you can only really use one hob because of the power sharing function. So then I'm back to hard wiring.
I have a Bosch double oven (HBN13B251B) on it's own 32amp circuit.
Oven is about 12m from consumer unit.
Would it be safe to connect a hob such as this one to the same isolator switch, or would I need a new circuit for the hob? (I don't have the option of rewiring at this point)
http://ao.com/product/pie651bb1e-bosch-serie-4-induction-hob-black-44838-39.aspx
Appliances always quote kw and not amps so I've no idea how much I can actually have.
Any help would be much appreciated.
