- Joined
- 5 Dec 2012
- Messages
- 1,012
- Reaction score
- 15
- Country
i have just built a curved front door step using some radial bricks. These have been laid on to a concrete foundation.
I have a bit of type 1 hardcore left, and a lot of gravel, so i have chucked a load of this in to act as a sub base. My only concern is that when i lay the sharp sand to which the block paving will lay on, that it will wash through into the gravel. is there anything i can do/buy that will fill in the gaps inbetween the gravel, so to make it compact, and firm base to lay the sharp sand on before paving?
Could i buy some ballast or building sand? Do i need to put a membrane down (if so, which type?) on top of the sub base, before laying the slabs with a 4:1 sharp sand and cement mix?
Many thanks
mark
Many thanks
mark
