- Joined
- 15 Apr 2017
- Messages
- 2
- Reaction score
- 0
- Country
The TRV on the (only) radiator in my loft is leaking from the pin and i now have a wet carpet. It's not too bad if the pin is in the up position, but if it is depressed then it begins to leak slowly.
Should i replace the whole valve?
If so, give it is the highest radiator in the system, can I avoid draining the whole system? Can I just drain to below this radiator and then top back up? What's the easiest way of doing this? Should I just use the bleed valve on the highest radiator on the floor below?
