The higher amp rating will not affect the operation of the hedge cutter,
The majority of wear and tear to micro-switches used to control motors happens when the switch opens ( switches OFF) as this creates an arc which wears the contacts. It might be worth buying one or two spare switches just in case.
The rating on the switch is 4(3)A which normally means 3 amps for motor load and 4 anp for lighting or heating loads.
